Slab and outer wall line not aligned
I have problem with some "little dimensions" appearing in drawings (0,01 cm e.g). These measurements make problems with section views-slab lines seen (usually when slab edge is nos aligned with outer wall face). When I zoom drawing I can see these small distances between lines. When I have big projects I cannot control all edges. I am interested is there any tolerance command which can prevent these issues; figuratively speaking- when everything which is closer than e.g. 1 cm becomes one (autocad has this tolerance with nodes). I will post some pictures to better understand issues which are worrying me.
Thanks!
In ARCHICAD there is no such tolerance setting as such.
You have cursor shapes that give you an indication about the proximity or element Nodes and Edges. You also have Cursor Snap Range setting in Work Environment Dialog>Input Constraints and Guides page that lets you define how many pixels close the Cursor must be to a Node or Edge to sense it. The maximum possible value is 9 pixels.
So you should always make sure you click only when the Checkmark Cursor shape is present.
You can also zoom in in such cases to make sure you find the exact Node you want.
Thanks for your answer. I saw that possibility before but thought that would not solve the problem. I will try with it again, if you re sure that there is no tolerance solution.
thanks!
Antonija
