artktecture
Slab in plan view with different line types for different edges?
Can you show a slab in plan view with different line types/colors/etc for different edges of that slab? Similar to being able to change the surface of one edge of the slab in 3D?
I have several floor composites that often butt up against each other and the 3D view is correct, however in the 2D plan view I'd like to turn the line off (shown in red) where they touch each other.
Thanks in advance!
artKtecture uses Archicad 24/Twinmotion
Lenovo Thinkpad | Xeon E2176M@2.70 GHz | 32GB | Quadro P4200 8GB
Oculus Rift S VR tours
Contour Rollermouse Red Plus (ditch your mouse and get one of these!)
Using a highly modified Shoegnome template (Thanks Shoegnome!)
1 Solution
Perhaps I didn't understand you correctly, but have you checked the 2D Representation of Connected Slabs on Floor Plan.
Hope this helps.
Go to post
2 Replies 2
Hope this helps.
artktecture
Hope this helps.
That was exactly what I was looking for. Thanks!
