2015-02-1101:38 PM - last edited on 2023-05-2505:39 PM by Rubia Torres
2015-02-1101:38 PM
Here's another issue I came across while working on a tutorial -
I copied elements from the 1st Floor to the 2nd Floor using the "Edit Elements By Stories" command. When going back to my sections the fill for the 2nd Floor slab is there, but the outline of the slab is not.
How did this happen, and how do I get the outline to show up?
Thanks in advance for any help! Screenshots below -
One possibility is that there are two Slabs in the same location. In the section, select the Slab and drag it vertically to see if there is another Slab in the same place, if so, delete one of the Slabs.
