Slab thickness - cant change
I am new to achicad 10. The option to change the slab thickness is in gray. Is there a way to edit it ?
Also is there a way to make walls or slabs invisible or like glass ?
Please help me out
7 REPLIES 7
Looks like you have a composite fill attached to it, if you change it to a vectorial & symbol fill you should be able to then edit the slab thickness.
Dwight
Making the walls and slabs 'invisible like glass' means either:
assigning materials like glass to them in the wall and slab dialog box,
or
MAKING UP AN INVISIBLE MATERIAL. That would be a totally transparent material.
Archicad 10 does not show transparency in the 3D window - you must render to see transparency.
Dwight Atkinson
woah fast reply, thanks guy for my probs solved
Hello Dwight,
You wrote: "Archicad 10 does not show transparency in the 3D window - you must render to see transparency."
In what sense do you mean this ?
I can turn ON or OFF transparency in shading in the 3D window in AC 10.
Thanks,
Peter Devlin
Dwight
Excuse me for the generality.
I forgot about the internal 3D engine since it is years since i used it.
My comment is specific to OpenGL in the 3D window. Finally enabled in V11.
Dwight Atkinson
Hello Dwight,
That's OK man. I forgot about OpenGL
Peter Devlin
Another option for semi-invisibility is to set the object's layer to WIREFRAME in the layer settings / combination. I do this occasionally for glass balustrades in elevations.
