Slabs unusable, Z height is Distance origin?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2016-07-19
04:19 PM
2023-05-25
05:38 PM
Rubia Torres
Ok, so drawing any slab I click and the start point (Distance) is the Z coordinate instead of zero. I drag in a direction and input a dimension. Then measure, it is some random distance (does not even seem to be the hypotenuse). The example I show was a countertop slab where I had input 3' as the slab offset from home story.
I had another drafter here try my file on his system but it's fine. Every drawing I open now has this issue. I tried reloading favorites. Tried applying the 'Standard Profile 20' work environment, no luck.
In the past I've had issues with hitting the backslash \ key and toggling the 'Prefer polar coordinates' checkbox. That one I disable the key now. But there seems to be a "Rotate XYZ axis, and randomize input" key that I hit the hotkey for . WHY-O-WHY do these hotkeys even exist Graphisoft?!?!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2016-08-18 03:14 AM
A client made me aware of this post. Luckily the issue was discovered back in July and it is already in the works to be fixed with a mainstream Update for ARCHICAD 20. I do not have a firm ETA for the Update but expect the first mainstream update sometime within 1-3 months.
For now there could be multiple workarounds including drawing the slab with 0' offset to start with and then elevate the slab after. Sorry for the inconvenience.
Best regards,
Technical Support Team - GRAPHISOFT North America
Tutorials
GRAPHISOFT Help Center
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2016-08-29 01:53 PM
Thanks for letting us know!!
Implementation Specialist
GRAPHISOFT
http://helpcenter.graphisoft.com - the ArchiCAD knowledge base
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2016-08-29 05:14 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2016-09-20 01:04 PM
GRAPHISOFT
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2016-10-28 11:52 AM
I'm on 4009 and it's not fixed at all.
It's impossible to use the slab tool in polygonal mode. The first line you draw is totally random. No mattter the value you enter via keyboard, it doesn't work.
AC 10-26 INT/GER/FR on Win 10/ Win 11
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2016-10-28 12:52 PM
GRAPHISOFT
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2016-10-28 11:56 PM
waiting...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2016-11-23 03:27 AM
Tested for: ARCHICAD 20 AUS, AUT, FIN, FRA, GER, INT, ITA, NED, NOR, NZE, SWE, UKI, USA
Last modified: November 21, 2016.
Other language versions will be released soon.
Best regards,
Tutorials
- « Previous
- 1
- 2
- Next »
- « Previous
- 1
- 2
- Next »
