Slanted wood frame window
How can I put wood frame and glass beneath slanted steal columns?
I've tried to do so with roof, but it's very hard to clearly positioned them.
( Slanted steal columns have different angles. See picture below).
And how about wood frame?
thanks!
AndrƩ wrote:
How can I put wood frame and glass beneath slanted steal columns? I've tried to do so with roof, but it's very hard to clearly positioned them.
Take a look at OBJECTiVE. Its "Assembly" tools allow you to re-orientate a collection of objects into a different working plane, make whatever changes you require, and then restore the assembly back to its original position in the model. It also provides tools for profiling, rotating, and cutting objects, which would make the modelling of the glass and timber frame quite straight-forward. For more info, look at: http://www.encina.co.uk/objective.html
Some of the assembly tools can be seen in action in this clip http://www.encina.co.uk/obj_assemble_movie.html
Ralph Wessel BArch
Central Innovation
Thanks a lot, I'll try it.
