Sloped Walls
Hey, im new to Archicad, currently using AC13. I REALLY need help, ive looking everywhere for an answer on sloped walls. I need a wall thats diagonal so it goes from level 2 down to level 1. (e.g. if you have a ramp i need a wall on either side of that, that lies up against the ramp).
Please provide steps in your response if there's a method
THANKS heaps!!!
8 REPLIES 8
Rod Jurich
First welcome to the forum. Second no need to make your query a poll, it makes no sense at all.
Now to your problem. It is quite easy. I would suggest you do as many before you and look in the
ref guide first or get some 1 to 1 training locally.
Ref guide is found in the Help menu or in the Documentation folder.
After you get though the guide then come back here for any clarification.
And finally please add a signature with your OS and version of AC.
Yes I am aware that you have 13
Rod Jurich
Good response, Rod.
Walls can not be SLOPED!.Anyway, here's an example how to resolve this:
Lol sorry about the poll thing, i just did post topic. not very familiar yet.
Thnx for your response Rod.
Andro how do i bring up that 'edit targets and operators' box
Rod Jurich
hrv00 wrote:
/....... how do i bring up that 'edit targets and operators' box
Again I feel you should spend some time looking in the Ref Guide.
Or just exploring the menus
Quite easy actually, but in the mean time ............
Rod Jurich
Dwight
Not in the way you might imagine. It is easy enough to make a simple ramp using the tilted wall feature.
Dwight Atkinson
Dwight
Okay. So i am an idiot.
What i meant was that if you put a tilted wall over a conventional wall such that their nodes touch, the tilt wall cuts the conventional wall.
Dwight Atkinson
It is possible to delete the Poll.
One needs to click the Edit button and in the appearing page there is a Delete Poll button after the poll question.
I deleted this poll so now it disappeared.
"Andro how do i bring up that 'edit targets and operators' box"[/quote wrote:
1. Menu Design>Solid Elements Operation or
2. activate the toolbar with Menu Window>Toolbars>Edit Elements (first icon on the right side)
