Guides and wall lengths
I got a new laptop, and thus I upgraded to Archicad 14.
The main problem here is that now when I try to make walls, the dialogue box that would pop up near the cursor doesn't appear. By this, I mean the box which shows how long you are making the wall etc... where you can type in the length you want etc...
Tui
David Maudlin
Tui:
Go to Work Environment > User Preference Schemes > Tracker and Coordinate Input and check "Show Tracker".
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
After following David's advice you will want to Redefine your W.E. or the next time you open AC you might have to turn tracker back on again.
