Snap at the end of a wall
Hi
I want to create a vertical wall which starts from the end of the one horizontal.
how can I do? if I select the point to start with the vertical wall, archicad shows me only 2 points (one on the left and one on the right). I want to have the exact point at the end of the horizontal wall.
thanks
I attach here images
Eduardo Rolon
If I understand correctly,
Try the following steps:
1. Select Wall Tool
2. Move mouse to the end of the horizontal Wall until a "checkmark" appears
3. Click
4. Type "Y" to restrict vertical
5.Type the distance you want and at the end type "+" to go up or "-" to go down
6. Hit enter
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
sinceV6
Hi.
By the looks of your screenshots, you have "snap to grid" on. Turn it off so you can snap to the wall end.
Best regards.
