Solid Element operation not working fully
Matratzis
Hi!
I got an Issue and would be happy to know if anyone knows a quick fix.
When working with the Solid Element operation It sometimes doesn't remove everything of the element. Hope someone can help!
Mathis
Architecture student from Germany 🙂
Currently learning basic modeling.
1 REPLY 1
Brandon-W_DWa
A few things you might try/check out:
  • Change the "Trimming Body" setting within your roof (it's under the MODEL tab group). There's only two options, but changing this may work better for your geometry.
  • Check out the priorities of your building materials. That could be preventing some geometry from going through the roof at all, then not getting cut by your SEO.
  • If it comes to it, you may need to adjust the layer intersection groups for the elements involved in this condition (for example make your walls and roofs different intersection groups).
Versions 25, 27, or 28
macOS Sonoma 14.7.1 - 2021 MacBook Pro 16", M1 Max Chip, 64gb DDR5
Browser: Google Chrome
Setup info provided by author
