Davor P
Solution to the top voted wish: Mesh with constant thickness
Should have probably been doing something else yesterday but can't help myself taking on a side quest. 🙂
https://community.graphisoft.com/t5/Wishlist/idb-p/wishlist/tab/most-kudoed
Reach out if you need this.
www.vktrs.co
41 Replies 41
Lingwisyer
Guru
Yeah, to me it looks like it somehow replaces the mesh surface with the object. If it is not built on the community object and is actually pulling the files Composites, that would be super neat.
Botonis
Mentor
In the info tab at the video a mesh is selected.You see also the blue contour line.
The nodes delected belong to the mesh.Changing the mesh updates instantly the o je t.
The mesh is just invisible (Maybe a transparent material)
So that means that a mesh and an object are in sync.
Davor P
There are 3 parts to this - original native Archicad mesh, the addon and an object. If mesh changes, the addon updates the object. Mesh is set to top surface only with same surface attribute that top layer of the object has but could be set to something invisible. Haven't tried to see if I can hide the top surface of the object. In any case, object needs to have each layer as solid body in order to show in cut. Source mesh can always be hidden by placing on different layer or design option.
I did see the community object but our object is built from scratch.
www.vktrs.co
Davor P
Also it is not pulling composites but it could. Currently I added 10 layers and you pick how many you need, material and thickness.
www.vktrs.co
Botonis
Mentor
Maybe the mesh should have a transparent material 100% so no additional settings are needed.
When can we expect the addon??
Very interested to see how you did this.
Keen to see if annotation in 2D/3D can be added to show falls, etc.
Matthew Johnson - POWE Architects
AC4.5 --> AC29 & Revit 2016 --> 2024
Asus Zenbook Pro 16x i9-13900H w/ Nvidia RTX 4070 4K dual, Windows 11 64bit + Quest3
I'd rather be sailing.
Lingwisyer
Guru
Even if you match the top surface, do you not sometimes get intersection artifacts?
StefanV_BCP
Would like to test it out 🙂
Stefan Veselinović
BIM Manager for Bureau Cube Partners, Serbia
WISH HUB: https://community.graphisoft.com/t5/Wishes/WISH-hub/td-p/393063
Laura Yanoviak
Me too!  Thanks.
SeaGeoff
Ace
Me too, along with everyone I know. Great work! Thanks.
Regards, Geoff Briggs
I & I Design, Seattle, USA
AC7-29, M1 Mac, OS Tahoe
Graphisoft Insider's Panel, Beta Tester
