Stair Cover Fill Problems
Eduardo Rolon
Two identical stairs with the same settings except that one has an Empty Fill and the other a Marker Fill. When you use any other fill that is not either empty or air space the background pen setting is over ridden by the "Visible Structure Pen" under the "2D Symbol Type" parameter and it ignores the "Background Fill Type Setting" pen.
Eduardo RolĂłn AIA NCARB
AC29 US/INT -> AC08
another Moderator
0 REPLIES 0
