Stair structure not showing in section
Yvonne
Is there a reason why the structure of a 2 riser stair won't show up in section but if I change it to 3 it will?
AC26 | Win11 | 64 bit | 32Gb RAM | Intel i9-9900K @ 3.60GHz
13 REPLIES 13
Hi Geof,
Thank you for checking!
The object might be locked that is why it cannot be deleted.
Please try to unlock all elements: Edit > Locking > Unlock all, it might help.
Regarding to your question please use this page to contact support.
Kind regards,
Dani Benjamin
Technical Support Engineer
Geof Gainer
No luck, thanks. But here's another project with the same problem, and I just noticed that in both cases, the stairs don't appear in 3D Docs with Renovation: Proposed, but they do appear in Renovation: Existing. See attached.
Screen Shot 2022-08-08 at 9.07.39 AM.pngScreen Shot 2022-08-08 at 9.07.24 AM.png
AC fan since v 7. Currently on AC 26 Build 5003 USA FULL, and AC 28 Build 3110 USA FULL, Apple Silicon,. 2022 Mac Studio, 32G ram. MacOS Ventura 13.7
Geof Gainer
...actually in this case, it's an elevation, not 3D docs.
Solved! I just selected the ghosted stairs, switched them all to Renovation: New, then switched them back to Existing. They all show up now.
