Stair with alternate treads
Achille Pavlidis
Is it possible to model a stair like the one in the picture?
Mac OSX 13.6.6 | AC 27 INT 5003 FULL
10 REPLIES 10
Model a staircase with the step depth being the lesser one. Then edit the step lines to adjust for the full depth.
You can model 2 types of custom Treads, save them using the "File > Librariers and Objects > Save Selection As > Stair Tread" menu command.
Then select the Stair and enter Edit Mode. Select every second Tread in Edit Mode and change them to one of the custom Treads you saved. Then select all other Treads and change them to the other custom Tread you saved.
Achille Pavlidis
is there a reason the custom treads are placed in a completely wrong place?
Does this have something to do with origin?
Achille Pavlidis
After a lot of trying I gave up and followed the advice of petsagouris, even though I had to manually draw every single tread.
I could not get the custom tread to be placed correctly. Even by starting with the stair and saving the tread as morph and then editing it, it was still misplaced. If I used a morph I made from scratch and saved as custom tread I got placed completely wrong.
It is a pity that this feature is so poorly implemented
Have you seen this Helpcenter article?
https://helpcenter.graphisoft.com/knowledgebase/74260/
Barry
Achille Pavlidis
No I haven't, I saw it now.
I was working on floor plan, so this "ghost preview" was not very clear in its purpose.
Any way I got the stair to appear as I wanted in 3D, but the treads still appear as before in floor plan. So the manual editing of every single tread is still the preferable solution. I think custom treads created from morphs should appear correctly on floor plan.
Were on earth would that stair meet any sort of building code? I am always curious about this when I see so many stairs of a unique design.
Erwin Edel
Some expats here like to joke that there is a reason the Dutch word for 'stair' is 'trap', since older houses here have notoriously steep stairs, but this wouldn't meet any code here either
Maybe in the nautical world?
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
runxel
Hero
It's a so called "Raumspartreppe" (space saving stair), or "Sambatreppe".
They are allowed, but only if you don't use it to access any living rooms, just for the attic.
Lucas Becker | AC 27 on Mac | Graphisoft Insider Panelist | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text | My List of AC shortcomings & bugs | I Will Piledrive You If You Mention AI Again |
