2005-01-26 11:41 AM - last edited on 2023-05-25 05:36 PM by Rubia Torres
2005-01-26 01:57 PM
2005-01-26 04:22 PM
2005-01-27 02:42 AM
2005-01-27 08:54 AM
Stress wrote:Hah, that was a good question! If Ihave a stair selected I can edit it or go to "create a new stair" -selection pane, every time. But if no stair is selected - only one access to make a new stair. Weird.
Is the stair selected when you open the stair tool?
2005-01-29 05:33 AM
2005-01-29 10:37 AM
Michael wrote:Yes, that was it. And the "blinking" seems to be only a fast screen redraw.
I have just managed to get the same instance happening in the office. What I did find though on PC no blinking occurs the pop up window just does not appear. I can still place the original stair i created and that is all.
I have found that to work around this without re starting AC you can open one of ArchiCAD's original stairs in the library modifiy it [say add another riser or similiar] place it in your model and the next time you open the stiar tool the create new stair will allow you access to the pop up menu. I didn't say this was smart but it does save you from quitting the program. you can then delete the stari you don't need [that AC modified one that gave you access to the menu again].Now I can live with this feature or bug, whatever. Keeping some stair selected when entering Stairmaker lets you also create new stairs.
Hope this helps, but the problem did not occur all the time.
2005-09-08 11:33 AM
kari wrote:Bug, I believe.
2005-09-08 08:35 PM
2005-09-13 05:25 PM
