Stairs in Plan view
I've searched the archives because I know this has been covered before, but I can't find it.
I am trying to edit the 2D view of my stairs in a +5 story building.
I want to be able to see the top of the stairs from the story below, and only see the 1st half of the stairs on the current floor.
Right now, I am unable to figure out how to have the stairs (arrows and all) turn off appropriately. I keep having overlapping items and it is confusing.
Does this make sense?
Honestly, the cut-off lines (sections lines) in the version 11 stairs are really silly... why does it just show the continuation of the stairs beyond the cut line, wouldn't it make sense to show me whats going on underneath.
Any help would be great...thanks.
17 Replies 17
__archiben
it's not the most intuitive of things to do -
you need to turn on storey sensitivity in stair object itself and configure the various 2D representation settings accordingly.
next you need to set the stair object to show 'on home storey and one storey up'
after than comes a whole bunch of fiddling, tweaking and general messing around until you have something that "will do" - because the end result with stairs is always far from perfect.
HTH
~/archiben
b e n _ f r o s t
Correct me if I am wrong, but I think that ~/archiben's way (And the way I handle it) only works with the "Create New Stair." I think if you just modify a stair out of the library you are not going to be able to get it to show up correctly.? You will be able to get the upper and lower parts to show up on their own floors, but, the ups and downs and arrows won't cooperate.
Oh, and- for the create new stair/~/archiben/my way of doing this you need also to turn on "Arrow Up/Down"
Jesikuh123 wrote:
Correct me if I am wrong, ...
I think you may be wrong, Jesikuh
You can edit stairs' properties and display parameters after creating them in the main stair dialogue.
__archiben
Jesikuh123 wrote:
Correct me if I am wrong, but I think that ~/archiben's way (And the way I handle it) only works with the "Create NewStair."
i never use stairmaker (the 'create new stair' option), so i know that it works for the stair objects in the library as well.
with regard to the arrow (and here is where i start a great big shit fight!) - from a graphic convention point of view, i don't believe that the arrow should show anything other than the 'up' direction anyway . . .
~/archiben
b e n _ f r o s t
~/archiben wrote:
with regard to the arrow (and here is where i start a great big <b>[censored]</b> fight!) - from a graphic convention point of view, i don't believe that the arrow should show anything other than the 'up' direction anyway . . .
~/archiben
CORRECT!
Laura Yanoviak
Ummmm... except the direction of egress is typically DOWN.
Regardless, we need to have more control of the 2D symbol, be it with a Stair object or StairMaker.
__archiben
since i threw the ingredients together, i feel compelled to give it a stir too . . .
egress is not a function of the stair - it's a requirement unto itself. but maybe your regs require it to be so - i can only imagine the confusion should someone overlook the little 'up'/'dn' text. out of interest, if you had a fire escape door at a half landing level do you have one flight showing an arrow up and the other showing an arrow down all within the same stair?
. . . or any object. my complaints over most third party additions to archicad are usually 2D representation related. stair graphic convention joking aside, an object's representation must be incredibly flexible. all too often developers of objects have one idea about how it should look and ignore the possibility that another user might need something else.
~/ben
b e n _ f r o s t
Laura Yanoviak
In commercial work, egress is typically the ONLY function of the stair (traveling between stories is what the elevator is for ).
Yep. And this is one thing that frustrates me about the available 2D symbols -- typically it's not one or the other: from an intermediate story, one flight goes UP and the other DOWN.
Eduardo Rolon
I'm with Laura on this. That is the way I wad taught to draw them.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
