Steeldeck roof problem
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
ā2010-11-19
03:43 PM
ā2023-05-23
02:53 PM
Rubia Torres
ā2010-11-19
03:43 PM
i'm having a problem by drawing a steeldeck roof on an industrial building.
I tried to draw it by the object 'Profiled Sheet Inc 13' from the archicad library 2010. The problem I have is the direction of the slope. I want the sheets to lay in the other direction put I can't find how to do this?
You can see on the image included what I mean. The sheets should lay in the direction of the red lines.
Thanks!!
5 REPLIES 5
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2010-11-20 10:10 AM
ā2010-11-20
10:10 AM
Hy Dave
This object needs an additional parameter for the "rotation about longitudinal axis". Maybe someone of the GDL gurus on this forum can do it?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2010-11-20 02:56 PM
ā2010-11-20
02:56 PM
Dave:
Strangely, the code is in the 3D Script as an option, but was not implemented (I don't know if this wall because there were odd problems with certain parameter settings that could cause issues the author did not want to work through). Open the library part, Save As.. a new object (to preserve the existing object), go to the 3D Script, and go to line 176 where you will see:
!if hor = 0 then do extrude 5,0,0,gesamt,48, sumw,0,0, sumw+wl/4,h,0, sumw+wl/2,h,0, sumw+wl*3/4,0,0, sumw+wl,0,0 sumw=sumw+wl while sumw<v !else ! rotx 90 ! roty 90 ! do ! extrude 5,0,0,v,48, ! 0,sumw,0, ! h,sumw+wl/4,0, ! h,sumw+wl/2,0, ! 0,sumw+wl*3/4,0, ! 0,sumw+wl,0 ! ! sumw=sumw+wl ! ! while sumw<gesamt !endifThis is an if/then statement for the direction of the corrugations in the sheet. The simplest solution is to reverse the commented out sections so the code reads like this:
!if hor = 0 then ! do ! extrude 5,0,0,gesamt,48, ! sumw,0,0, ! sumw+wl/4,h,0, ! sumw+wl/2,h,0, ! sumw+wl*3/4,0,0, ! sumw+wl,0,0 ! ! sumw=sumw+wl ! ! while sumw<v !else rotx 90 roty 90 do extrude 5,0,0,v,48, 0,sumw,0, h,sumw+wl/4,0, h,sumw+wl/2,0, 0,sumw+wl*3/4,0, 0,sumw+wl,0 sumw=sumw+wl while sumw<gesamt !endifThis object will only do the horizontal corrugations, like the original only does vertical. If you want to spend more time, you could uncomment all the code and add a parameter hor that controls whether the corrugations are horizontal or vertical.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC28 USA ā¢ Mac mini M4 Pro OSX15 | 64 gb ram ā¢ MacBook Pro M3 Pro | 36 gb ram OSX14
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2010-11-20 03:34 PM
ā2010-11-20
03:34 PM
Dave wrote:Try OBJECTiVE. It adds tools to easily cut/rotate objects in 3D. With your roof, for example:
- 1.The profiled roof lying on the level.
2. Switch to a section view looking along the profile, selected the profile, clicked the menuOBJECTiVE > Tools > Rotate, clicked the rotation origin, and the start angle.
3. Set the angle of rotation.
4. The finished rotation in section.
5. The result in 3D.
Ralph Wessel BArch
Central Innovation
Central Innovation
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2010-11-20 10:55 PM
ā2010-11-20
10:55 PM
That's annoying accessory limitation !!!!
Another simple solution is the Complex Profile: create a section along the roof slope the width of each deck panel sheet and lay them down across the roof slope using the beam tool.
Dwight Atkinson
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2013-12-02 01:51 PM
ā2013-12-02
01:51 PM
I am having exact same problem. profiled sheet has a slope but only in one direction which makes it useless in some situations, eg. supporting beams are sloping and profiled sheet is on them (obviously direction of the steel profiles depend on the supporting beams rather than pitch of the roof. Can somebody explain how to solve this problem ?
