Stretch Relative/Absolute
Zdenko
read most if not all of the posts i could find on stretching and have not been able to solve? i have a beam that simply needs to be stretched 12' on either end. seems yesterday stretching elements was not a problem. for some reason when i try to key in 12' it gives me either a stretch down near the origin of 0,0 or it gives me a beam that is exactly 12' long or it moves it to the left of the end point of the beam itself? i have gone bonkers selecting/deselecting switches in the tracker and work environments to the point i have no clue what is what anymore. any suggestions?
Operating system used: Mac Apple Silicon Sonoma 14.4.1
Archicad 27 5030 USA Full Apple
M3 Max 36GB MacBook Pro
iOS Sonoma 14.5
17 REPLIES 17
hey buddy appreciate all your help, but i give up!. my tracker changes from 3 lines (distance, angle to z) and sometimes it shows (distance, angle, x, y, z). tried to use "-" and still get the same inconsistencies. resorting to guidelines...
iOS Sonoma 14.5
Hi @Zdenko,
In addition to all explained above by Barry I tried to show stretching technique in a short video, it may help more.
* I could stretch the wall by 2 ways, either typing the total desired length in Distance area or putting the distance I need to add to or subtract from the wall.
- For example, I need to stretch a wall = 2-meter length,
1) Select the wall, to see the reference line location.
2) Click on the black dot at the wall end, don't move or press shift.
3A) Type 3 in Distance area then it'll be 3-meter length, or type 1 to be 1-meter length.
OR
3B) If you type 0.43+ in distance area you get it 2.43-meter length, and if you type 0.43- you get it 1.57-meter length.
* As you see sometimes you need Archicad to calculate it for you.
** All this should be applied provided that you activated the Relative coordinates in tracker as Barry explained above.
*** Sorry if + & - are not shown in the window background but I hope you guess their positions correctly.
**** Pls watch the attached video below while applying the above-mentioned steps.
AC 27 INT 5060/WIN 11
hi Mahmoud - generally speaking most of my stretching is related to increasing/decreasing the element by a specific distance as you have shown. looks like the "+" is working and understand but what am i doing wrong with the "-".
iOS Sonoma 14.5
@Zdenko, I see you're using Mac, right?
Sorry I'm using win. so, I think you should manage this minus operation, try to put minus before the number & see if it's going well.
no problem and appreciate the assistance Mahmoud.
iOS Sonoma 14.5
Because you are Imperial measurements, I think you may have to type '-' twice.
i.e. 2 - -
The first minus is a shortcut for feet I believe.
I am not 100% sure, as I do not use Imperial measurements.
i.e. 2 - -
That is correct, need to type "-" twice.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
thanks guys that was it.
iOS Sonoma 14.5
Setup info provided by author
