Starting August 6, 2024, TLS 1.2 will be the minimum required protocol version for Graphisoft products and services that require an online connection. Learn more…
Stretch cabinets height, makes archicad gets stuck
Stephania
Hi!
I recently downloaded ArchiCAD 27. Before it was really easy to stretch the height of a wall cabinet in the 3d or interior elevation but now whenever I try, ArchiCAD gets really slow, gets stuck and just wont stretch the cabinet to a desired reference point. Any solution for this?
Thanks!
8 REPLIES 8
Roger C
Can confirm this behaivour too in Archicad 27.1.1. This needs a solution ASAP.
i7 3770K / MSI GS73VR 7RF i7 7700HQ
16 gb
GTX 3060 / GTX 1060
Windows 10
ArchiCAD 25 SPA
I have 4001 USA FULL ArchiCAD 27.
Looks like the same issue happens with other "Objects". I doesn't happen with walls, slabs, windows, doors. But it doesn't happen with all objects. I was able to stretch the height of a chair.
how?
@Stephania wrote:
how?
@Stephania ,
There was no solution by the person you replied to.
That was a spam post just so they could place a link to something unrelated to Archicad in their signature.
That post and user has been removed.
JJMARQUEZ
Make a copy of the object and select both. You will see that now it works. You can also select any two and it will work.
Vaclav Slovak
Here the same problem - please solve it as fast as possible. very annoying 😞
