Stretch house?
I have a simple rectangle house in progress with slab floor, walls, and structural beams present. I am looking to adjust the width of a certain section of the house between two columns. Can I use the marquee tool to stretch the house along an axis so that i can change one bay from 14' span to 16' span without having to go in to the walls, beams, and floor slab individually to change them?
6 REPLIES 6
basically i am just changing this dimension from 14 to 16 feet
Erika Epstein
Yes. The heavy marquee will do all stories, the light marquee just the one you are on.
Be sure to:
-Turn off any layers you don't want affected
-make sure grouping is suspended
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Thanks i got it
Djordje
Also make sure to:
- unlock all the layers that you do want affected
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Also make sure to:
Turn off Grouping
Gerald Hoffman
“The simplification of anything is always sensational” GKC
Archicad 4.55 - 29-Latest USA
2024 M4 Max MacBook Pro-macOS 15.5 (128GB (16 Core CPU + 40 Core GPU)
And show also layers with all SOE elements.
