Thursday
I need to substract an elipse form shape from a Zone. In the picture attached, the gray is the zone, and highlited is the area I need to substract. I can´t do it with the regular tools option I have to substract and add area for the zone. Any ideas?
Solved! Go to Solution.
Thursday
Hi @maurotrotta
You can draw the ellipse with the Arc/Circle drafting tool and activate Related To Zone to Zone Boundary. Then use the zone construction method of your choice. That ellipse can be in a hidden layer if you want.
Best regards.
Thursday
Hi @maurotrotta
Best regards.
