Subtracting CW from a Wall
MuazOnline
Hi everybody,
am trying to subtract a CW (operator) from a Wall (Target) in vain ...
it shows me that the operations is OK, however on the 3D window everything is still in its place and no change is achieved !!!
5 REPLIES 5
Eduardo Rolon
Have you put the operator in a different layer (SEO layer) and turned that layer off?
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
MuazOnline
well actually i need to keep both of them
the normal wall
and the curtail wall
and all i need to do is to create a hole in the wall using the boundary of the curtain wall ...
Eduardo Rolon
Ok I misunderstood.
Instead of using SEOs you can put an "empty window" in the wall and put the CW in it.
AC27 US/INT -> AC08
another Moderator
MuazOnline
many thanks eduardo
will try this one
You probably also want to give your "empty window" (that eduardo suggested) a unique name or letter to be able to exclude it from your window schedule.
