sknsnw9
Surveyor's Unit not working?
I'm currently working on the site plan.  I have the dimensions set to surveyor's unit, but in the tracker the angle isn't changing to display the degrees, minutes, seconds.  Am I missing a setting somewhere? I can't draw my property lines at all.  I'm able to get the length to work, but not the angle.
Archicad Solo 24 - 28 : Windows 10 Pro 64-bit : 16 GB ram / Intel Core i7-4770k @ 3.50GHz : NVIDIA GeForce RTX 3060 / MacBook Pro M3 Max
1 Solution
JaseBee
There's actually 2 settings, the dimension units (for dimension tools display) and working units (for data input and tracker).
The option you're looking for is under, options - > project preferences - > working units.
AC 24 5004 AUS
iMac OSX (10.13.6) 4.2ghz i7
8gb ram/8gb vram
Go to post
3 Replies 3
JaseBee
AC 24 5004 AUS
8gb ram/8gb vram
sknsnw9
I missed that one.  Thanks. Is there a way to make that working units based on which view map it belongs to so there's no need to switch back and forth?
JaseBee
Not that I'm aware of, we're always switching in our office between meters and millimeters depending on who's in the project (has no effect on outputs though).
AC 24 5004 AUS
8gb ram/8gb vram
