‎2022-02-13 10:23 PM
I'm currently working on the site plan. I have the dimensions set to surveyor's unit, but in the tracker the angle isn't changing to display the degrees, minutes, seconds. Am I missing a setting somewhere? I can't draw my property lines at all. I'm able to get the length to work, but not the angle.
Solved! Go to Solution.
‎2022-02-14 12:29 AM
There's actually 2 settings, the dimension units (for dimension tools display) and working units (for data input and tracker).
The option you're looking for is under, options - > project preferences - > working units.
‎2022-02-14 02:56 AM
I missed that one. Thanks. Is there a way to make that working units based on which view map it belongs to so there's no need to switch back and forth?
‎2022-02-14 05:04 AM
Not that I'm aware of, we're always switching in our office between meters and millimeters depending on who's in the project (has no effect on outputs though).
