Inglewood78
Suspend group not working
I'm having an issue with the "Suspend Group" command in my current project. When I try to select a wall that's part of a group, the program automatically selects the entire group in a "Suspend Group" mode. However, when I start a new project, the "Suspend Group" command works normally, and I can select individual elements within a group. I'm wondering if there's a way to fix this.
1 Solution
That wall is not grouped with anything, so no matter what you do, it will not make a difference.
You need to group the walls first before you can suspend them.
You can turn the auto-groping on for continuous elements like walls and lines that you draw in one operation.
Go to post
5 Replies 5
I am confused by the image you show.
Grouping is not suspended - the button will be highlighted when it is.
And the wall is not part of a group anyway - the nodes will be round coloured circles rather than black dots.
Can you show the same image but with the problem group?
Inglewood78
Image 1 :suspend command is not select. when I select wall.  wall is separate and not connect.
Image 2: Suspend command is turn on. Wall still not connect.
Inglewood78
This wall create by new Project is look ordinary wall continued by chain (Image3) But if i use previous project wall still single not chain wall.
Inglewood78
Berry that is very help me so much. Billion thanks for your help.
This command is blind spot for me. (Autogroup)
