2025-09-09 06:48 AM
I'm having an issue with the "Suspend Group" command in my current project. When I try to select a wall that's part of a group, the program automatically selects the entire group in a "Suspend Group" mode. However, when I start a new project, the "Suspend Group" command works normally, and I can select individual elements within a group. I'm wondering if there's a way to fix this.
Solved! Go to Solution.
2025-09-10 06:17 AM
That wall is not grouped with anything, so no matter what you do, it will not make a difference.
You need to group the walls first before you can suspend them.
You can turn the auto-groping on for continuous elements like walls and lines that you draw in one operation.
2025-09-09 07:20 AM
I am confused by the image you show.
Grouping is not suspended - the button will be highlighted when it is.
And the wall is not part of a group anyway - the nodes will be round coloured circles rather than black dots.
Can you show the same image but with the problem group?
2025-09-10 06:03 AM
Image 1 :suspend command is not select. when I select wall. wall is separate and not connect.
Image 2: Suspend command is turn on. Wall still not connect.
2025-09-10 06:10 AM
This wall create by new Project is look ordinary wall continued by chain (Image3) But if i use previous project wall still single not chain wall.
2025-09-10 06:17 AM
2025-09-10 07:08 AM
Berry that is very help me so much. Billion thanks for your help.
This command is blind spot for me. (Autogroup)
