ā2005-10-21 04:01 PM
ā2005-10-21 04:44 PM
ā2005-10-21 06:19 PM
ā2005-10-21 07:01 PM
Tom wrote:You can create two draft files, but they must have different areas, layers, sections or details in each draft. You actually cannot open an PLP file, you can only sign in.
If I create two draft files, then send them home with two different staff over the weekend, does that mean I have to leave the .plp file open all that time? That can't be right. Surely I must be able to close (save) the plp file somehow, then reopen it on Monday, then receive changes from the draft copies.
If I do work on the .plp file at the office during the weekend, how do I save that information and update the existing .plp file?
ā2005-10-21 07:08 PM
Tom wrote:When a person signs in to a PLP, they take a part of it for themselves. If that person saves, they save a draft PLC, not a PLP. The PLP is never really open. If you have not saved, you are technically working in "untitlled.plc". Only the "Send & Recieve" command actually affects the PLP file.
ā2005-10-21 07:25 PM
ā2005-10-21 07:50 PM
Do I then sign out, which closes the plp file?Stop thinking about opening and closing the plp file. To make your changes stick, send and receive, as you said. Following that, by signing out you are giving up your privileges and workspace defined when you signed in...another person is free to sign in and work in that area now.
ā2005-10-21 08:47 PM
Tom wrote:The only time a PLP file is actually changed is when you Send & Receive.
I think I'm starting to get the picture. One more question, if you please. If the plp is never really open, why am I able to do work on it? I'm signed in as the team leader, and am making changes to the plp. How do I incorporate those changes? By executing the send and recieve changes command? Do I then sign out, which closes the plp file?
I think I'm close to understanding the big picture. I've got a project due on Monday, and the teamwork thing is the only way I'm going to be able to get it done. Unless I screw something up with teamwork, which can and probably will happen (based on my previous experience with computers in general)
ā2005-10-21 11:06 PM
ā2005-10-21 11:55 PM
Tom wrote:You would not be able to have two drafts that have the same workspace unless you did a save as.. from your draft file to make a copy. In any event the first send from and receive from Draft A would change that draft's ID number and Draft B would then be invaild and would not be able to send and receive changes. As you said there are opportunities to screw up, but at least they are limited. As long as you keep up with where you save the drafts, and overwrite the old draft (so you do not keep multiples) you will be fine.
Getting closer and closer. Hypothetical question..... I have two draft copies, and they both have the same reservations made. Two different people work on them. Now I have to send and recieve to the PLP to update the project.
Draft copy A sends his changes and the plp updates.
Draft B send his changes and the plp udates.
What if both A and B made changes to the same thing, which they could do because their reservations are the same. Would the PLP show the last changes, which would from Draft B? Would that receive overwrite the changes from Draft B?
Now that I write it all down it seems so. Am I right in the above assumption. It looks like I found my opportunity for the screw up here.
