Text Problem
Hi, when i select my text height, to make it bigger for titles etc, it gets thicker also, i want it larger but thinner, how can i achieve this? thanks.
12 REPLIES 12
TomWaltz
I think most Archicad Fonts are TrueType or OpenType, so they act like a font in any other program. Unfortunately, that means that the height of the font and the stroke thickness are related.
Tom Waltz
Link
You can change the text's 'Width Factor' to as low as 50% (and as high as 1000%).
Link.
nar nar nar, im talking about the thickness of the actual line makeing the text, not the actual width of the text as one.
Abode
Link
How eloquent.
As Tom says, it's a true type font. So you're SOL. Maybe consider a thinner font.
Link.
got any ideas for a thinner font than arial?
cheers,
Abode
Eloquence (from Latin eloquentia) is fluent, forcible, elegant or persuasive speaking in public. It is primarily the power of expressing strong emotions in striking and appropriate language, thereby producing conviction or persuasion. The term is also used for writing in a fluent style.
So, eloquent i am 😉
Link
cheers,
Abode
Yep - Google and the tiniest amount of your own effort.
Link.
oh well cheers, thanks for you effort cheers cheers cheers.
Abode
Link
See - you're putting Google to good use already!
Good luck with the font.
Link.
