David wrote:
Jeff:
I posted a split face block texture here:
Split face concrete block, anyone?...
I'd just like to add that the Swedish concrete texture library (mentioned in the thread David linked to above) has moved to the location
http://visualiserabetong.cementa.se/DATA/movie.htm
(BETONG = concrete, VISUALISERA = vizualize)
I'm also quoting fmr's explanation of how to get the textures:
Fmr wrote:
Hello Dan
You don't need to download the file for ADT 2004, he doesn't works with ArchiCAd at all.
You just need to download EACH texture one by one by "HƤmta textur" in the site with a great choice of options.
When you download a texture, you get a .zip file which contain 3 files each time :
by example
ā Master_gdl_RƤfflad1_S.GDL (that put the materiel automatically in your ArchiCAd menu)
ā rƤfflad_Stor.jpg (The "texture for mapping)
ā Read_me.jpg (that you don't need to drop to your library, if you drop this file more than one time you may have an error)
Be careful to the Ƥ, the ƶ and other swedish particular characters, after downloading some texture I have a message error and i need to rename the texture file where the Ƥ or ƶ "going away"ā¦
I Hope that "explanations" help you, if you have more problemsā¦
Some additional explanations:
Look for the sub-menus
MARK = ground/site coverage
ā PLATSGJUTEN = poured/cast in situ
ā PREFAB = (this will be an exercise for you)
BYGGNAD = (concrete in) building(s)
ā FORMMĆNSTRAD = patterned from the formwork
ā FRILAGD = exposed (aggregate)
ā SLIPAD = sanded, honed
Select a category in the sub-menu, and you get another...
VĆLJ = select
ā KULĆR = color/hue
ā FĆRG = color as opposed to GRĆ
= grey
ā GJUTFORM = mold, formwork
When you've made your selection, you get a
VISA TEXTURER = show textures menu (button)- Click it and then select your texture.
The
HĆMTA TEXTUR = get texture button will give you a choice of the texture's
ā
svarthet
= darkness (litterally blackness, only for some textures)
ā
storlek
= size (in pixels, click the INFO button), and
ā (file)
format
Then click the
Ladda ner = Download button
You will have to do this once for each and every texture you want.
And do follow fmr's advice above to remove the Swedish characters. Some OSs don't like them in file names.
The whole package of textures as one single download is only available in ADT format,
nowadays at this location
http://visualiserabetong.cementa.se/DATA/files/Visualisera_Betong_ADT2004.zip
In that 10MB file, all the textures are available
but only as jpegs. If that is all you need, you can download the file and extract the jpgs even if you don't have ADT.
On a Mac, download the zip file. You will find that it's a self-extracting .exe file that you can't run on a Mac. But you can right(crtl)-click. Select Open with, and use the Unarchiver to extract it's contents. Then download a program called
Filejuicer from the Internet, and drop the data1.cab file on it. It will extract all the jpg texture files along with some other content.
On Windows you should be able to just download and exctract the contents.
