2025-01-13 11:37 PM
Good evening,
I am working on my ArchiCAD model and, suddenly, the wall textures changed without me knowing how. Additionally, the object selection is offset, and the snap points seem strange. Could you help me?
2025-01-14 01:28 AM
Textures changing mean you have probably amended a surface material attribute.
Did you overwrite and surface materials in your attribute palette/manager?
The offset selection lines is usually an indicator that your model is set up a long way from the project origin.
You should always model close to the origin.
2025-01-14 12:41 PM
Hi thanks for your answer
I did not change the surface so i dont know why it's happening and i am modeling close to my origin point
I am lost sorry
2025-01-15 01:55 AM
I don't see the Project Origin in your image.
A blue XYZ marker.
Not to be confused with the User Origin which is black and can be placed anywhere.
