3 weeks ago - last edited a week ago by Karl Ottenstein
When working Design Options with section or facade , the function does not work correctly with 2D elements that are blocked but not hidden.
It's strange that so far no one has paid attention to this.
Fix it soon!
Operating system used: Windows 10
3 weeks ago
Can you please give a bit more detail about this issue?
When you say
"the function does not work correctly with 2D elements that are blocked but not hidden",
what do you mean exactly?
Can you give us an example, maybe a couple of screenshots that illustrate the problem?
Also, you are stating that this happens in Archicad 28.2.2. Currently, there is no such version. The latest is Archicad 28.0.2. Is that what you mean?
3 weeks ago
Can I send a video? Only in it the essence of the problem will be clear.
3 weeks ago - last edited 3 weeks ago by Laszlo Nagy
after checking a test file I also have a problem when turning on or off design option sets in the design option manager then 2D items stay on for previous combinations.
but when i use the design option combinations the problem goes away.
yellow fill on "TEMPO" design option
change to "VERVE" design option set in Design options.
yellow fill in "TEMPO" design option set still visible
green fill in "VERVE" design option set
change to design option combination and it reset back to correct view.
windows
Archicad 28.0.2 (3110) AUS FULL
P.S.
after rolling the install back, i discovered that the problem is also present in the original installation:
Archicad 28.0.0(3001) AUS FULL
this does not happen in Archicad 27.
3 weeks ago
This is definitely a flaw in the program (this is not observed in AC27).
I'm not asking for help or any advice. I just want to draw the developers' attention to this bug and ask them to fix it in the next update.
3 weeks ago
Please do.
You can attach files to your reply.
3 weeks ago
You can also post videos of up to 75 MB is size.
a week ago
or post a link to the video file
a week ago - last edited a week ago
I would recommend keeping the video size below 75 MB and posting it here because then it will be permanently stored on the Community site. In the case it is stored on another website and a link is provided, if the file is removed in the future on the remote site, the video will be permanently lost for the community.
a week ago
I had a bit of a play around and found that the 2D fills in elevation in different design options do not immediately display (or disappear) when switching design options.
But a rebuild and regenerate does force them to show correctly, CTRL+ALT+SHIFT+R is the shortcut on Windows.
Hopefully drawings on layouts should be fine as they rebuild themselves automatically.
