Eduardo Rolon
Three Buttons for One Tool - Sections, Elevations + Int Elev
Three tools for the same procedure, might it have not been better to create a tag to choose from in the S/E tool panel?
I.E. group with:
  • elevations
    sections
    interior elevations
____
Imagine how I will teach this 3 tools to my next group of students in their AC class.
Professor- For elevations you have to use this tool, For sections this one and For IntElev this one.
Student- But aren't these three things the same just with different settings, WHY are they different tools?
Professor- Because GS in their Infinite Wisdom decided that we needed special icons for each
Student- OOOOOOOOOKKKK…, If I make a mistake and I choose the wrong one (because of a copy) is there a button to change it to the other type?
Professor- No, you will need to erase the previous one and create a new one
Student- Why?
Student- And in how did it work before? Weren't you able to create sections and Interior Elevations?
Professor- It was one tool were a section was called "SECTION", an elevation was called "ELEVATION" and an interior elevation was called "INTERIOR ELEVATION" each with its own marker.
Student- And that procedure does not work anymore?
Professor- Yes it still does
Student- Then, Why create separate icons for what is essentially the same tool?
Student- Isn't Autodesk the only one that puts new icons for the same commands and calls it an UPGRADE?
Professor- Not anymore…
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
46 Replies 46
Eduardo Rolon
Link wrote:
Hey Eduardo
During the beta I pushed to keep them all as one tool pretty hard, but to no avail. Must be a trainer thing hey? I think the whole toolbar could do with a lot of streamlining, combining all line and dimension tools, removing the wall end tool etc. There is nothing here that favorites can't handle.
If GS wants me to help them convert new users to AC they are responsible to make it easy. The section tool in SketchUP is also used for foor plans and I never see a student complain about it since the basic definition of a section is that it is a cut no matter the direction. AFAIK the Big money come from new users not from existing one so making it difficult does not make sense.
Link wrote:
BTW the last S is for Stupid....
Link.
I knew but I already compared GS to Autodesk and didn't wanted to get banned.
Karl wrote:
…A single button/tool with subcategories/modes could still retain the defaults for each subcategory...and if the user changes a section to an elevation, I don't see why the nav item cannot be automatically moved to the proper place.
What's so difficult about understanding this?
___
GS please keep it simple and keep it flexible. AND whenever possible remember that we work in a Graphic Field and it is easier to understand a diagram than to read thru a list (sun settings in the "NEW and IMPROVED" section, elevation and interior elevation tools. My chosen profession is Architect not Archicad user.
the concept should be
  • Autodesk = Complex and difficult to use
    Graphisoft = Fast, Easy, Flexible, even a Child could use it
AC29 US/INT -> AC08
TomWaltz
ejrolon wrote:
[My chosen profession is Architect not Archicad user.
Statements like that always make me laugh.
Some things come with the territory. Sales rep, drafter, teacher, renderer, marketer, drawing checker, emailer, typist, spread sheet data entry, and <gasp> CAD user are all things that an architect (or ANY professional) may be expected to do in their life time, even though they are not really "architecture." You're not a union laborer. A littler versatility and adaptability is expected.
I'm not thrilled with every decision GS makes either, but we can either accept it or start learning how to be a user on another software.
Tom Waltz
Laura Yanoviak
Well put, Tom -- I think I'll add that to my next e-mail-to-staff.
Eduardo Rolon
Agreed, but my invoices always say:
"… for Architectural services rendered"
not
"For the use of Archicad to prepare the construction documents for the project XYZ"
AC29 US/INT -> AC08
TomWaltz
not
True.... nor did they say "unclogging Rapidograph pen for use in architectural services" 😉
Tom Waltz
Eduardo Rolon
But neither Kohinoor nor Faber Castel made Rapidographs that need 3 different tools to unclog nor caps that behaved differently like the 3x0 cap unlocked the right, the 2x0 unlocked to the left and the 0 pen cap was a pull out.
They all behaved in the same way and if you made a mistake you were able to remove the cap from the wrong one an put it were it belonged. You were not forced to throw it into the trash and buy a new rapidograph.
Simple and Consistent.
AC29 US/INT -> AC08
TomWaltz
Yeah, it's all fun and games until someone puts the .35 cap on the .50 pen....
The scary thing is that half the people here are probably too young to get the joke!
Tom Waltz
Eduardo Rolon
Naah, we used to change the point, it really messed people up.
AC29 US/INT -> AC08
Unclogging pens, that was a nice little break away from the drawing board... those were the days.
I remember back in the "olden" days at my first job I got a new nib for my 0.18 (a staedtler I believe). The 0.18mm was lovely, gold plated, a piece of precision equipment. Had it in my hands for 2 minutes, someone flicked a rubber band at me across the office, dropped the pen, bent the tip, stuffed it.
TomWaltz
Getting back to topic.... the more I think about it, the more and changing my mind and starting to agree that the section, interior elevation, elevation, and possibly even isometrics/cameras could all be combined into one tool... I think my objection was to it being a "Section" tool. I think it would be better called a Live Model View tool or something to that effect, that lets you create either linework or rendered views from a single view point. This would also allow the "skewed elevations" that I've seen requested for sloping walls and would allow <gasp!> real ceiling plans since you could possible rotate the cut to look upward.
Tom Waltz
