Tip: How to unhang ArchiCAD 9 under Vista
I am using Vista and sometimes I have to use ArchiCAD 9 on it, while ArchiCAD 9 is not supported under Vista, having been released much earlier.
I found that if I go to any other program, ArchiCAD 9 hangs and I have to force quit it.
However, recently I accidentally found the solution:
I go to any other application, select something and press CTRL+C to copy it to the Clipboard. ArchiCAD 9 miraculously comes back to life and continues to work fine. If it happens to hang again, I repeat the same fix and it is again in good working order.
Maybe it happens only on my machine, but let's hope this info is useful for others, too.
Some of us experienced AC 9 hanging under XP related to the clipboard:
http://archicad-talk.graphisoft.com/viewtopic.php?p=53246&highlight=copy+hang#53246
(and earlier posts). Could this Vista thing be related? It sounds like you did not do a ctrl-C in AC, but merely switched to another app to get AC 9 to hang?
Thanks,
One of the forum moderators
AC 27 USA and earlier   •   macOS Ventura 13.6.9, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Thanks,
Yes, I switch to any other app, Windows Explorer, mail, browser, anything, and AC9 hangs. Then I do a CTRL+C in any app, and it unhangs.
