Link
Tip: Redefining Display Option Combinations
It has just occured to me that many people are unaware that you can redefine display option combinations, so I would like to explain how simple it is:
In the Display Options dialog, select the Display Option Combination you would like to change from the drop down list;
Make any changes you want;
Hit the Save As... button and delete the word 'copy' *and the space that precedes it*;
Hit Save;
Hit Replace in the next dialog;
Hit OK.
Any views that are using that display option combination will be automatically updated.
Link.
4 Replies 4
Steve Jepson
Great sugestion. Thanks.
__archiben
it never used to 'redefine' itself if you did this: it (AC8? 8.1?) used to throw up the "same name..." message. i tried it recently too, and found what you've discovered.
you beat me to the tip though, no.2 . . .
~/archiben
b e n _ f r o s t
Link
Well timing is everything isn't it? Afterall, that's why you can say no. 2, right?
Cheers mate!
Link.
__archiben
speaking of which . . . isn't it past your bedtime?!
cheers!
b e n _ f r o s t
