Tool-box
It sounds stupid- but the toolbox disappeared. When I opened the file It wasnt there. What to do? Thanx.
Im working with version 8.
6 REPLIES 6
Window menu/palette display/show toolbox
I tried that. Thanx Mike... I found it when I turned on full screen- It was hiden very well in right low corner of screen. How it came there i dont know.
Steve Jepson
I remember that happening to me too. It was very frustrating. I don't remember what the problem or the solution was. It never happens to me anymore. When you figure it let us know. I am still curious about that.
Try loading the default Work Environment, or restart ArchiCAD with New & Reset (both Project Settings and Work Environment set to default).
Ben Odonnell
try this
HTH
Cheers.
Ben
Ben O'Donnell
Architect and CTO at BIMobject®
Get your BIM objects from bimobject.com
I have been having similar problems. My pallettes and work windows are moving around a little just enough to cover scroll bars and other little items. Also the toolbox is changing shape and size. This only happens when I am switching between 2d section and 3d views, and the pallette settings in the menu will reset back to my standard. i find myself doing that 3 or 4 times a day when working in the model. 8 had bad layouts but they did stay put.
