Tool changes from 8.1 to 17 (what happened to the shortcuts?
I just upgraded from Version 8.1 to 17. (Big leap, yes, I know, but it suited me well for 10+ years.) At this point I'm sorry I had to upgrade. For example, what happened to those handy shortcuts for navigating the stories (command-6 to go up a story; command-5 to go down; command-8 to hide or reveal the ghost story; command-4 to show story manager window, etc)? Is there some substitute or are they gone?
If there are no shortcuts how do we hide/reveal the ghost story w/ Version 17, anyhow?
34 REPLIES 34
At the expense of being a pest I have another issue. This one is truly a work-stopper. In 8.1, if I wanted to draw a 2-ft long line perpendicular to, and below, a horizontal line I had already drawn I could do it by placing the cursor at any given point on that line, followed by these commands:
A 270 degrees
R 2'
Now whey I try to execute the above this is what happens: The windows shows 270 degrees but then as soon as I enter the "R" value a so-called "Tracker Line" (heavy dashed format) at a default angle of 16.28 degrees appears on the page and the 2-foot line I want to execute simply extends 2 feet in the zero angle direction.
Same thing happens when I attempt to "drag a copy" of the horizontal line 2 feet in the 270 degree direction: the "Tracker Line" suddenly appears at 16.28 degrees from horizontal.
What's up with that?
Could you post a screenshot? I am not even sure that thing you call a Tracker Line is called that. I think you may be talking about a Guide Line.
Hello Laszio
The PDF labeled "Tracker Line-16.28 degrees" is a representation of what I described in the previous email. The "tracker line" does would not show up in a PDF so I over-drew it w/ the red dashed line. The "tracker line" appeared on the screen as a light brown heavy and short dashed line~same as in the JPG "PHOTO-Tracker Line." But I have not been able to duplicate precisely what's depicted in the PDF ~probably because I monkeyed around with some of the setting hoping to solve the problem in a hit and miss fashion. Nevertheless I still am not able to project lines from the location of the cursor at the angle and and distance I desire. In sum, I'm not able to draw (except by employing a convoluted work-around using circles to determine begging and end point of every line).
I am attaching a series of screen shots ~produced w/ a digital camera because it's not possible to take a screen shot of the information boxes.
First off, my objective is to draw a 2-foot-long line perpendicular to and downward from right end point of the 3-foot long horizontal line. But I can never get there ~using the procedure of 8.1, as illustrated by the following series of screen shots.
The numbered the photos correspond to the following actions (assume north is up):
1. Arrow tool is at east end point of a 3-ft horizontal line whose west end coincides with the Origin
2. keystroke: "A"
3. enter numeric value "270"
4. keystroke: "R" NOTE: Angle is involuntarily changed from 270 to 180 degrees; a new line has been subtended at an angle of 225 deg from the beginning point; an a vertical dashed "tracking line" running through the Origin has suddenly appeared.
5. The cursor is now at the end of a newly drawn line whose end points are our beginning point an a point 2 feet south of the Origin (see photo #6).
Not at all the line I am trying to execute.
Briefly I thought that if there were some way to make the program think that my starting point is the Origin I could make it work. To test this notion I tried drawing the same 2 ft line with the beginning withe the Origin as the starting point. I won't burden you the "screen shots" but I can tell you that the result was a 2 ft line on a zero degree heading from the origin.
So there you have it....what can you tell me?
P.S. I see just now that a max of 1 attachment is allowed in this forum. So the others will have to follow one by one.
Cannot upload the 6 screen shots, apparently because they exceed the pixel width and height limits.
I think you are talking about Guide Lines.
What happens if you right-click the Guide Line and select the "Remove all Guide Lines" command of the context menu.
Can you then perform the action as expected?
I don't think the guidelines are interfering with the operation I want to perform. But I'll try that & let you know.
No, that didn't help.
I am simply trying to project a line (or it could be an object or the first leg of a multi-line or a fill) for a distance 2 feet in the "southward" direction from the point where I placed the arrow tool.
In 8.1 this was a very handy operation and simple to execute with these key strokes:
A (for angle)
followed by the point of compass direction from the arrow tool IN DEGREES (based on the X, Y grid where due east is 0 degrees, north is 90 degrees, etc) ~~In the case, 270 degrees
R for distance in the selected heading
numeric value of the distance (in this case 2 feet)
In sum, the strokes looked like this:
A 270 R 2' and I would have been able to draw the line.
However NOW in v17 what happens is this:
With keystroke "A" the information box pops up with Angle active and reading 0.000 degrees
With keystrokes "270" 270 is actually entered in Angle window
BUT as soon as I keystroke "R" to enter the distance the Angle defaults to 0.0000 degrees.
So the program will let me draw a line only the 0.0000 degree direction (due east from the point I have selected.
Bottom line: I really don't care about the guide line. What I care about is being able to simply be able to draw a line where I want it. As it is I cannot perform the basic task of drawing simple lines. So what V17 procedure replaced the V8.1 procedure I described above? The 8.1 procedure was so logical and elegant in its simplicity I can't imagine it being done away with. Is there perhaps a simple matter of adjusting a setting somewhere that would prevent the program from defaulting to the 0.0000 degree direction after I tell the program what direction I want to head?
David Maudlin
Randall:
What happens if you reverse the order of the commands? R 2, A 270. In this case I would use the "Y" coordinate: Y 2-- (the first "-" is the separator between feet & inches, the second for the negative direction).
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC29 USA Perpetual • Mac mini M4 Pro OSX15 | 64 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
Hey, David, thank you, thank you. That did it! No negative indicator required, however.
I'm back in business!
BTW, I could find figure out how to add my signature.
Randall wrote:
...BTW, I could find figure out how to add my signature.
In Profile, link above
