4 weeks ago
Hello, does ArchiCAD have any function that can directly show me the building’s top view as a floor plan?
Solved! Go to Solution.
4 weeks ago
The way I see it, you can either:
- go to the last floor in your project map. Select the floor plan cut plane to show all the floors underneath. Make sure the stuff on other floors isn't set up to just show up on the home story. Then you should see everything.
- select everything in 3D, go to axonometry, go to top view - save the view as a 3D document. This is less flexible than the first method but it can work.
4 weeks ago
3 weeks ago
CosminF hit the nail on the head. I think wether you go floor plan with a full floor plan cut plane range or 3d document depends on what graphic out put you are looking for
3d document is going to read more like an elevation, whereas floor plan is going to give you the symbolic appearance ofhte model
3 weeks ago
Do note that not every element has an All Relevant setting, and hence would need to have it's visibility controlled by Layers if it is not to be seen on other plans.
Ling.
