Tracker input- feet vs inches
Tom Krowka
If project preferences are set to inches, how can I get the tracker to accept feet. Or can I. Have been avoiding the issue for a while and just converting, but it seems one should be able to input values either in feet and inches or just straight inches.
Tom Krowka Architect
Windows 11, AC Version 26
Thomas@wkarchwk.com
www.walshkrowka.com
5 REPLIES 5
David Maudlin
Tom:
Change the Working Units to Feet & Inches, and when you want to input just inches, use ' 0 - X ' where X = inches, or ' X" ' where X is inches with the inch symbol/indicator.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Tom Krowka
I guess the key is the hyphen before the inches. Never knew that.
Thomas@wkarchwk.com
www.walshkrowka.com
You can also use the "/" key after the number for inches. example 8/ is 8 inches. it does not sound like much, but you are pressing a single key instead of the shift key plus ".
Tom Krowka
Thanks. Will try that out also.
Tom
Thomas@wkarchwk.com
www.walshkrowka.com
David Maudlin
This works if the Working Units is set to Feet & Fractional Inches, but not if set to Feet & Decimal Inches, unfortunately.
