ā2008-12-16 05:00 AM
ā2008-12-16 05:11 AM
ā2008-12-16 05:18 AM
ā2008-12-16 05:26 AM
ā2008-12-16 05:50 AM
ā2008-12-16 12:37 PM
GeNOS wrote:'find and select' is your friend here!
mision to change all teh windows glass. but probably the only way.. cheers
ā2008-12-16 02:46 PM
GeNOS wrote:You could also simply use solid fills with no edgeline in the elevations to make some windows appear solid where necessary. You would have to remember to adjust them manually if the window changes size though.
Is there a way I can make some windows and or elements transparent in elevation and 3d and others not..
ā2008-12-16 06:32 PM
ā2008-12-17 04:49 AM
ā2008-12-17 06:47 AM
vfrontiers wrote:This is the best for what im trying to achive
While we're throwing stuff out there....
You could also create a layer for WINDOW BLOCKOUTS and place little slabs just behind the windows you want NOT TRANSPARENT. Use Layer Combos to toggle this layer on/off to your liking.
Trouble will be if you want some blocked out sometimes and transparent other times.
