We value your input!
Transparent walls in plan view?
Kamelite
Is it some way to make transparent in plan view? Inside the red circle there is a window. But I can't see it because of the wall..... Is it some setting in MVO or something that can make it transparent, so I can see where the window is?
.Kamelite
Windows 10, Archicad 27
8 REPLIES 8
Lingwisyer
Guru
The default Site Graphic Overide has transparent walls? A few of the others do too.
Or if you are talking about an actual window in a second wall, not a trace, could you just change your display order?
[Select wall with window] => Context Menu => Display Order => Move to Front
Or if you are talking about a window in a wall below the cut plane, you could set a small segment of the wall containing the window, to display as cut.
Wall Settings => Floor Plan and Section => Floor Plan Display => Symbolic Cut
Ling.
Or possibly the window is below your Floor Plan Cutting Plane?
Adjust the FPCP height, or set your walls and windows to 'Symbolic' rather than 'Projected with Overhead'.
DGSketcher
Legend
As Barry indicated ensure the windows are set to symbolic. In addition to checking the cut plane height you should also check the cut plane range to ensure the window is included in the range to get the symbolic display.
Kamelite
I see now I didn't explain the case good enough: I have a DWG as a T'nR. As I draw a wall, it covers a part of the .DWG. The DWG describes a window in that wall, but because of the wall, the exact positioning of the window is hidden. Is it some way to make walls in general transparent through MVO or something?
.Kamelite
DGSketcher
Legend
In the Trace reference settings you can have a trace reference on top and you can have transparent fills & zones.
Lingwisyer
Guru
Going back to my original post, if you use Graphic Overrides, you are wanting the rule "All Cut Fills: Transparent, No Skin Separators".
Ling.
David Maudlin
Similar issue discussed here: AUTOCAD TO ARCHICAD FOR TRACING EVERYTHING.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Kamelite
This was the trick I needed! Thnx!
-Kamelite
