Triangular Walls
Hey folks, i was wondering if anyone could help me, i'm trying to draw a wall in ArchiCAD which is a triangular shape. I don't know if its possible with the wall tool. I've tried a few different things but nothing seems to be working.
Any help is appreciated.
Thanks =]
4 REPLIES 4
I have found a way to do it...but not quite there yet.
I've drawn in a full wall and using the windows > openings > inclined top 12
But i need it to be horizontal instead of vertical. I can't find an x n y coordinates i can change... Any suggestions?
Thanks again.
Eduardo Rolon
Kawsome,
You are highjacking a thread, usually you create a new thread for a new question that is different to the one discussed it is easier to answer.
For your question it is usually easier to post a sketch of what you are trying to do.
Anyway if I can guess what you want the answer is in the help file under Trim to Roof, you might also read about Solid Element Operations.
HTH
Eduardo RolĂłn AIA NCARB
AC29 US/INT -> AC08
another Moderator
It was my thread initially, thought it'd be easier than posting more threads. sorry...
I have just used the wall tool i got it too work okay, just need to try do slanted windows now.
Thanks tho =]
I split the threads so now this is in its own thread.
