Trim-to-Roof a Wall of Hotlink Mod?
Hi all,
I have hotlink modules in the master file. I want to trim-to-roof certain walls of Modules in the master file but I can't.
Am I missing something or is it impossible?
Thank you
4 Replies 4
Guru
Have you tried with groups active? It feels inconsistent to me, sometimes it will let you, other times it will tell you that it is not editable... Also, select the operator first.
Ling.
Ling.
Thanks for your reply.
It does not let me do anything, even when I try group active. I also tried SEO but it does not work either.
Any solutions to it?
Thank you
Hi
Did you get a solution to this?
I've got the same issue. Not sure if its possible though.
Guru
Have you tried changing the order you add things to the operation?
