Trying to create own fill but screen only pattern appears
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2013-10-02 09:36 AM
so I am trying to create my own fill, and so far I believe I have done everything right. Created a pattern pure out of lines, copied pasted it on Fill types. But when i actually do the filling it copies the screen-only pattern. What am i doing wrong?
thanks
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-10-02 11:12 AM
Did you use the Line Tool or the Polyline Tool to draw the stencil?
I think you have to do it with the Line Tool, the Polylines will not be copied/pasted.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-10-02 02:29 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-10-02 02:32 PM
Make sure Vectorial Hatching is checked on.
Graphisoft Senior Product Manager
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-10-02 02:59 PM
by the way maybe you can also help me with something. So I have archicad Student version 17, and my library is ok but somehow my graphic hatches are not appearing. for example for insulation or gravel, It does not show the graphics. That is why I am creating my own hatches.
any idea?
thanks
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-10-02 03:04 PM
sseordio wrote:You're welcome.
Man you are a genius!Thanks,
any idea?
thanks
You can try checking the Model View Options, under Override Fill Display.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-10-02 03:13 PM
let me try to explain it in a better way:
so for example when I click on wall under Geometry and positioning on the right side i can define how the wall is build with which materials. If i choose concrete for example the left box shows a ? indicating the graphic is missing, while the right box is grey as the material should be.
I am using Archicad for mac so the interface might be slightly different!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-10-02 03:17 PM
If there is a "?" that usually means the attribute is missing because it has been deleted. The result will be a solid fill in any view. Try to apply another fill to the element. Also, some images would help.
Edit, sorry I see that it's AC17. Same thing about missing attribute. AC17 brings Delete and Replace, so you shouldn't have a "?" appear.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-10-02 03:21 PM
So i tried deleting my library and importing it again and i get a message saying missing objects - from attributes and then a list of all the materials. Why is that? how can i fix it?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-10-05 10:06 PM
