Roopa A
Twinmotion-Sun shadow setting
In twinmotion, where to activate the sun shadows, In my model, the shadows are not showing to adjust as in Archicad.
But after rendering, the sun shadows are seen.
I need to check the shadows after rendering only..
Roopa A S
3 Replies 3
Twinmotion sun is separate, and should already be showing by default. What gpu do you have?
David Collins
Check the quality settings in Preferences. TwinMotion manages the framerate of the display by disabling features in the background based on the quality settings and available memory, but when it renders an image or video it will try to give you everything its got.
David Collins
Win11 64bit Intel i9 3.40 Ghz, 64 Gb RAM, GeForce RTX 5080
AC 29.0 (3100 INT FULL)
Roopa A
Thank you, it is working.
Earlier it was with Low quality..
Now  I changed that to Medium quality, and the shadow is also showing now.
Thank you
Roopa A S
