Twinmotion does not import a complete Archicad model
archigreen
I realized that Twinmotion fails to import accurate Archicad models; even without "Optimize the geometry" selected. Bathtub have holes for example. How can I fix that?
Thanks for your time.
ArchiGreen
ArchiCAD 26
MacOS Monterey
MacBook Pro Apple M1 Max
64 GB
MrC
in Twinmotion, select bathtub material and toggle "two sided material"
ILIFFE ARCHITECTURAL
BRITISH COLUMBIA
macbook pro 2.7 GHz Intel Core i7 8 GB 1600 MHz DDR3 NVIDIA GeForce GT 650M 1024 MB
AC 21 USA (latest build)
5 REPLIES 5
What are your default settings, screenshot maybe?
Also do not optimize, and no merge. Deselect exclude items smaller than xxx
Are you using fbx import or syncing from Archicad?
PB
Should you decide to update to Archicad 23 or later (AC20 in your signature), exporting your model through the Datasmith workflow would likely be much better. Links below will help:
https://www.unrealengine.com/en-US/datasmith/plugins
https://docs.unrealengine.com/4.27/en-US/WorkingWithContent/Importing/Datasmith/SoftwareInteropGuide...
https://graphisoft.com/downloads/addons/datasmith-exporter
AC28. Twinmotion.
16" M1 Max MacBook Pro 32GB, Apple Studio Display, MacOS 15 Sequoia
archigreen
I'm sorry, my info is not up to date. Where can I update?
iMac, Mac OS Big Sur 11.6
3.6 Ghz 10 Core Intel Core i9
64 GB 2667 MHz DDR4
Graphics AMD Radeon Pro 5700 XT 16 GB
Archicad 24 built 6004
I'd like to ask you if you could share a snap-shot of a bathtub in Twinmotion. I'd like to see if your bathtub is complete.
Thanks
ArchiCAD 26
MacOS Monterey
64 GB
MrC
BRITISH COLUMBIA
archigreen
Great! It works. Thanks a lot!
Cheers.
ArchiCAD 26
MacOS Monterey
64 GB
