‎2021-10-07 10:51 PM
I realized that Twinmotion fails to import accurate Archicad models; even without "Optimize the geometry" selected. Bathtub have holes for example. How can I fix that?
Thanks for your time.
ArchiGreen
Solved! Go to Solution.
‎2021-10-08 08:22 PM
in Twinmotion, select bathtub material and toggle "two sided material"
‎2021-10-08 06:17 AM
What are your default settings, screenshot maybe?
Also do not optimize, and no merge. Deselect exclude items smaller than xxx
Are you using fbx import or syncing from Archicad?
‎2021-10-08 10:01 AM
Should you decide to update to Archicad 23 or later (AC20 in your signature), exporting your model through the Datasmith workflow would likely be much better. Links below will help:
https://www.unrealengine.com/en-US/datasmith/plugins
https://graphisoft.com/downloads/addons/datasmith-exporter
‎2021-10-08 04:57 PM - edited ‎2021-10-08 05:14 PM
I'm sorry, my info is not up to date. Where can I update?
iMac, Mac OS Big Sur 11.6
3.6 Ghz 10 Core Intel Core i9
64 GB 2667 MHz DDR4
Graphics AMD Radeon Pro 5700 XT 16 GB
Archicad 24 built 6004
I'd like to ask you if you could share a snap-shot of a bathtub in Twinmotion. I'd like to see if your bathtub is complete.
Thanks
‎2021-10-08 09:34 PM
Great! It works. Thanks a lot!
Cheers.
