Tom Krowka
Two story window
I have a big window that is half on the third floor, half on the second floor. Where do I put the window so it cuts out of both floors. Or how else do you handle that situation. Make an empty opening in one of the floors?
Tom Krowka Architect
Windows 11, AC Version 26
Thomas@wkarchwk.com
www.walshkrowka.com
10 Replies 10
Link
Yes! For example you could put the window in the upper wall and an empty opening in the lower wall - one that matched the size and location of the window. You could maybe consider copying and pasting the entire wall and simply switching out the window and dragging it up into place.
To get the window represented on the lower floor plan, simply put in a very short window (say a couple of inches high) with the same width as the multi-story window, and give it a negative sill height so that it is hidden under the wall, in the slab. If it still appears in section/elevation/3D, then you can put in a temporary flat roof at the bottom of your wall and trim your roof to it, making sure that Doors & Windows is ticked on.
How's that for a workaround!?
Link.
Tom Krowka
That is quite the workaround. Too bad there is no choice of "what floor to show this on"......both stories. But then you'd show two windows in elev.......never mind.
I'll use it anyway.
Thanks
Thomas@wkarchwk.com
www.walshkrowka.com
I'll use it anyway.
Thanks
This is a long standing wish. It has been the same tedious workaround for years when all we need (in most cases) is the ability to show walls on multiple floors. Maybe in AC9?
Showing walls on floors above/below/all stories like slabs & objects has been long requested and a high priority need.
Another workaround is to place the window in a wall the exact width of the window and and bottom elevation at the bottom of the window. I usually place it on the upper floor so that the top of wall can be trimmed to the roof. In the lower floor, place a wall w/ no fill & line weight matchiing window trim where the top of wall would be at the bottom of wall w/ window. Copy the wall with the window, paste in floor below, explode to create a group of lines. I find this easier to update, since you can drag the wall w/ window around in elevation/section/3D window or change the height. If the window changes, simply stretch and/or copy/paste/explode again.
Yet another way: Put same wall on both floors; hide one in layer combo for elevations, sections, and 3D views.
What a pain!
Djordje
Now this is upstream from anybody else, but I would put each half of it where it belongs. Depends on the type of a winow, really - I suppose it is something like glazing or a curtain wall - and you can turn off the bottom and top mullions.
Quite different from a case where you have, let's say, a high door or a window in a wall that is half its height, and another wall on top (same storey or not) with different properties; in this case, and empty opening is the cure. Best aligned in 3D fat marquee of course ...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
I think if you don't build second floor's wall and make first floor's wall in two stories' high, than you can make window in between two floors.
Good point Djordje. This is the best method when the window can be represented by the combination of upper and lower parts.
Link
Ouch! That's bad advice! This will not show the window on both stories!
Link.
Link.
Not if you don't want the window to show on both stories. It's rare but I've had it happen. Of course the wall is another matter...
