Unable to Group Beams Together
Deep
In the attached file, please find a video showing that I cannot group two beam elements. Is there no way to group them?
Archicad 24
Edition Windows 11 Home Single Language
Version 22H2
Operating system used: Windows 11-22h2
Archicad 24
cuba
Apparently it is not possible to group beams in a section or elevation.
But you can group them in plan view and they will also be a grouped when you open the section.
Apple M1 Max 32 GB Ventura
AC27
cuba
AC27
Thanks @cuba ! It worked!
Archicad 24
mthd
Ace
@Deep, I too have been stumped by this problem. I would make a wish.
Thank you @cuba, for the work around.
GRAPHISOFT please make it work in section and elevation please.
AC8.1 - AC28 ARM AUS + CI Tools
24C GPU 7.8TF 32GB RAM OS Sequoia
Setup info provided by author
