‎2004-06-15 02:37 AM
‎2004-06-15 10:42 AM
‎2004-06-16 02:30 PM
‎2004-06-16 03:22 PM
‎2004-06-16 03:53 PM
Just in case anyone is not aware of this, it should be pointed out that the numbers in the coordinates palette are rounded from their actual values and do not constrain them to the numbers displayed. I have had clients (neophytes) who were using the rounded numbers in the coordinates as confirmation that they were drawing to the correct length rather than using numeric entry. Needless to say, the models were riddled with tiny inaccuraciesLet me see if I understand what's going on here. Are you saying that the coordinate information is not really accurate. That would mean that drawing to some distance shown in the coordinate palette is not really correct to the numbers shown, regardless of the accuracy setting.
‎2004-06-16 06:54 PM
Tom wrote:The coordinates display MAY be correct if the actual dimension can be expressed by the level of accuracy defined. If a wall is precisely 8'-0" long then it will display the correct value.
Everything should be drawn using numeric entry? That means I have to find the distance for things that must be drawn. What happened to drawing from point to point? Shouldn't that be totally accurate? I think that is where our problem, and my question is. If I draw to a snap point, like a wall intersection, what difference does it make if I have one decimal place or four decimal places. It should still snap to that point, right?Snaps and constraints precisely accurate. I was referring to drawing a new element whose end point (or intermediate points) do not have a known point to snap to. In this case numeric entry is mandatory.
‎2004-06-16 07:48 PM
‎2004-06-16 08:47 PM
Tom wrote:As a rule elements should be stacked precisely on one another. Is there a reason that you need all these nodes and edges so close but not aligned?
We still have some snap problems. The pixel accuracy is set to one pixel. When it's zoomed in close, the actual points of the intersection of the lines or whatever it is do not stack up one on top of the other no matter what the settings are. This seems to be especially critical in roofs. Sometimes you just can't zoom in close enough to get two points to match. I think we must be doing something wrong here. Are we trying to be too accurate?
‎2004-06-16 10:18 PM
‎2004-06-17 12:49 AM
Tom wrote:Matthew's advice regarding the use of snaps, guidelines, constraints, and numeric input is spot on. You should never draw 'by eye' on the computer unless you do not intend to measure anything from the drawing, i.e. you are producing a schematic illustration. Even then, it's often easier to use snaps.
