Unwanted line between wall and slab,how 2 get rid of?
Mats_Knutsson
See attachment. I would like to get rid of the little line where the wall meets the slab. I somewhere feel I should know how to do this but I can't so please help! Materials are the same, pen colours are the same.
Best regards,
Mats
AC 25 SWE Full
11 REPLIES 11
Maybe the connection of the upper wall with the slab is not accurate
What about if you break the upper wall to 2 different walls at the level of the slab?
Mats,
I have noticed that I am unable to make the side surface
of a slab clean-up with a wall. The top edge and the bottom edge
always clean-up but never the sides.
Peter Devlin
Mats,
You asked, "how 2 get rid of?"
One way is as described below (see attachment).
Please note that circular slabs always have a minimum
of two vertical "edges" so you must orient the slab
so that these "edges" are buried.
Peter Devlin
Mats_Knutsson
Peter wrote:
Mats,
Peter Devlin
Haha!!!
That was a really shrewd (do I spell it like that?) work-around! It doesn't work all the way though. When I export it to dwg there will be some small annoying lines left. I don't know if it's a bug or if it's a decision from GS not to let the wall clean-up with the slab side. I will post lettter to GS and ask them. Thanks anyway for the tips!
Mats
AC 25 SWE Full
Clever solution, Peter.
GS, is this how you envision the model/documentation relationship working?
How long have we been asking for things to just clean up already!?!
Those little lines are the biggest driver of workarounds, maintenance, and wasted time.
ArchiCAD is a good modeling program, with good documentation ability, but the big selling point is the integration between the two. Which is totally belied by glitches like this.
It must be made a top development priority to ensure that a tight model generates tight drawings, automatically. It is way overdue.
James Murray
Archicad 27 • Rill Architects • macOS • OnLand.info
Here is a classic clean-up problem we all have run into
countless times (see attached).
Finaly, after all these years, I made a dumb little library part called
"3D Edge Mask" that you place in 2D or 3D to fix such problems
so you can get on with what you were doing.
It's basically a stretchable, rotate-able "slab" of the proportions
of the slab that I described earlier but its edges can be shown
for placement and then hidden to function as a mask.
Anyone is welcome to it, or make your own.
Peter Devlin
TomWaltz
Too bad there's not a Display Option to control this or something.....
Tom Waltz
LiHigh
You can replace Wall #3 with Column or Beam and must overlap wall #2, then the clean up is fine!
Howard Phua
Win 10, Archicad 19 INT
This is true.
Peter Devlin
